Icom IC-F420 Programming
K0LTZ
Vadnais Heights, MN
Hello ladies and gents. I have acquired an IAS desktop repeater based on two IC-F420 mobiles. Using a DOS installation from the hard drive of a PC using a true serial port, and known good Icom programming cable, I get errors regarding creating a local file when I try to read the codeplug. I have tried any and all settings that I know of, and cannot get it to work. I have tried all versions of the CS-F300 RSS I have with no luck. Any help is appreciated.
jeatock
090-45-50 W, 39-43-22 N
If you are using a known good cable that communicates with a newer radio, such as a F121 or F5021, that cable won't work on older radios
F3/400 radios and FR3/4000 repeaters use the single 3.5mm stereo pin portable cable and 3.5mm to RJ45 adapter. Icom part numbers are OPC-478 for the 3.5mm cable and OPC-592 for the adapter.
You can easily Google for specifics.
K0LTZ
Vadnais Heights, MN
You hit the nail on the head. I don't know how I missed it....OPC-1122 VS OPC-592......Yeah, I had my dumba** hat on. Now to decide if I want to bother tuning down T-Band radios to where I want them.....
