For the FR3000/4000, when does the TOT reset? On my Motorola, you get the courtesy/TOT reset beep right after someone stops transmitting and then the repeater TX stays on for a few more second before it stops. I thought that this was the normal operation.
On my ICOM you can't seem to program the TOT reset interdependently from the hang time (Hang ON for ICOM). I have the RPT Log set for L-off and a DTMF code set. My Hang ON time is 2sec. The thing is there is quite a delay after you un-key before the beep. It seems to me that it sends the beep right before the hang time expires (basically the 2 sec) , because it sends the L-off tone, then immediately stops Tx (hang expired). I tried setting the OFF delay timer to zero, but that did not make a noticeable difference. So is the TOT reset the L-OFF beep, or does it not reset until the Hang ON expires?
So when does the TOT reset and is there no way to have the TOT reset (and courtesy beep) but keep the TX (hang time) on for a little longer after that?
