Hello,
I have an IC-FR4000 UHF repeater, and I can't find any setting to change the CWID speed (WPM)
What it's set now to is excruciatingly slow and unusable.
By contrast, I recently programmed an IC-FR5000 and a setting for speed was clearly available.
Also, a problem my IC-FR5000 has that I'll assume the 4000 will have also is ...
When the repeater is idle, I don't need the CWID, however the repeater belts it out at the set interval 24/7.
Is that the limitations of the machine, or am I going to have to get a real controller? .....
