PhaedrusZen
How's it? I'm completely new to radios, and am learning on the fly at my job. I've been tasked with taking over radios for my department (maintenance, programming, etc) and we've previously been working with the F70s. We recently purchased 5 F9011S's, and I've got the new software/cloning cable up and running. The software interface is similar to the F70 setup, but after setting up my clone, when I try to write to a handheld, I get the following message:
"Connected transceiver is not compatible model.
Check the following:
- Appropriate cloning software for the transceiver is being used.
-The revision number of the transceiver."
I'm using the CS-F9010/F9510 cloning software with an OPC-1862 cable. All I can think of is the fact that there is some way to initialize a first time setup on my new handhelds that I don't know about. When I click the "Clone Info" button, I get the same message as when I try to write a clone to the handheld. I'm still learning the jargon, but any help/suggestions would be appreciated. I'll keep tweaking things as I go...
Stuff I've tried already:
-I checked the program I'm trying to clone to my radio, and all fields are showing no errors, with the exception of the "Trunking" section, which has a red "X". We're currently not using trunking, so I would think this shouldn't be a problem, especially when I even try to just get the clone info...
- I've verified that I'm using the correct Port setting (COM 5).
-I've tried every combo of initiating the clone I can think of... (connect cable, then turn radio on, connect cable with radio on, connect to radio, then PC, etc...)
-The cable driver is the most recent version.
...that's about all I can think of.
