Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > ICOM Land Mobile Radio
ICOM Land Mobile Radio - Discussion forum for ICOM land mobile radio equipment such as the IC-F series radios. Please do not post amateur radio topics here.
Old 07-11-2017, 5:38 AM
Default IC-F70S Scanning help
Hello all, quick question. On my F-70, I have it set up to have scan enabled at power on. Whenever I key up the mic, it turns scan off, requiring it to be manually turned back on. This is moderately annoying, and potentially problematic due to my service covering such a large area that we are dispatched not only by our dispatch, but three additional regional centers. If I fail to remember to turn it back on, I may miss a tone. If anyone is able to direct me to the right setting in the programming software, I would be very appreciative. Thank you.
Old 07-11-2017, 6:50 PM
You'll need to use the auto reset (TIM-A & TIM-B) in the common screen. Set the desired time in seconds. Under the memory channel/zone screen select the appropriate timer under auto reset field. I usually set one timer to "off" and the other for resume scanning after TX. I do this because if you have 2 tone decode set up it will auto reset if you don't use the "off" timer, which i particularly don't like.
Old 07-12-2017, 4:19 PM
Thanks, all figured out.
Tags
ic-f70s, icom
