JMBissen
Hello, I recently purchased an ICOM F521 from ebay. I have programming software and the cable, and was able to program the radio the way I wanted, however, I ran into a problem when I turned the radio on to use it. All of the channels i programmed have squelch issues, as in when nobody is transmitting all i hear is static. How do I correct this? What is the proper squelch setting? The range value it gives in the program screen is 0 - 250. Thank you!
