IC-F30GS Speaker Mic Issue
jdomke1
Manteca, CA
I own 3 IC-F30GS radios. Recently I decided I wanted to add a speaker mic for each. Only one seems to work with the accessory. I've verified the speaker mics all work. I just can't understand how two won't work but the other will. It's been a long time since I programmed these but each was cloned so I can't imagine it's something in the programming but I'm scratching my head here. Any suggestions?
zrock
First thing that comes to mind is you cloned from the one that works.. may have not cloned settings/preference
Sent from my SM-G903W using Tapatalk
jdomke1
Manteca, CA
I went back and re-cloned them... still nothing. The mic works but not the speaker. Perhaps one of the pins are bad on the radio itself?
12dbsinad
More than likely it's the accessory connector on the radio itself. Some of the older radios did not use a flex cable and directly soldered to the board. Can't remember if the F30 falls into that category, But for sure a bad design.
jdomke1
Manteca, CA
I agree but the accessory connector is also used to clone and that works. It’s used for the speaker mic and the mic works. It’s got to be just one or two pins bad that are for the mic. Any one have a schematic showing the pinouts? Would it be worth the money to get repaired at my local 2-way radio repair shop?
12dbsinad
Just to clarify, you get no RX audio from the speaker mic but transmits fine?
It could be bad solder joints on certain pins. It's a relatively easy fix if someone is good with an iron.. But don't spend much as that is a 15+ year old radio and wouldn't be worth it.
jdomke1
Manteca, CA
I’m going to search and possibly create a new post but here is my follow up question. I bought an F33GS and need to know. Is it possible to clone Icom radios that use different versions of the programming software? I have F30GS that I’d like to clone to a F33GS. I have the cables and software for each. I just don’t want to manually type in 180+ channels and the respective data. Thank you.
