IC-F1610 + UT-109 Scambler PCB
Sputnik1
Kettering - Northants - UK
Hello all
I wonder if anyone can guide me on this......
I have a brand new 1610 programs perfectly. I have fitted the UT-109 scrambler pcb
cut the PTT splash pad and programmed it with several different inversion codes
But.............
Scramble function not working.
Have tried via front panel toggling command and via permanent ON within program
I have even tried several different 109s just in case but all with the same effect
anyone any ideas ??
thanks in advance
rgds
Sputnik 1
N2AL
Tennessee
It’s been a number of years since I programmed an ICOM with scramble capabilities. BUT if I remember correctly, I had to enable the scramble toggle on/off button, but I also had to enable another setting inside the programming software. Unfortunately I do not recall what that setting was.
All this was after I successfully installed the UT109 board and properly cut the connections on the board and such.
Sorry if this is vague but I hope it helps you somehow.
