12dbsinad,
Thanks for the great information. So I got the MM firmware today. It's installed and I set my alert tones to "standard", which I assume is the standard Minitor alert?? I do not have a test environment to trip this radio anytime I want and our county test paged tonight. I am not sure if I haven't done this before which is why I never noticed it but here is what happened.
My radio was in scan with priority going to my county paging frequency. Which is also set to decode the 2tone. When my departments tones were sent my radio was receiving but never alerted and was locked on my priority channel. Did this happen because it was in scan? I am thinking probably so, I actually forgot tonight was a test night and had it in scan. I figured since the priority A channel is the channel that was set in the scanning that it would be ok and actually alert. Am I wrong and because it was in scan it won't alert?
I have another channel set to decode tones which is set to be inaudible until receiving the tones and I am assuming that all is well it was just because I had it in scan and it simply won't alert any channel when in scan even if scanning priority and that channel is the priority channel.
If you could please let me know your thoughts on why that didn't work. I can't remember if I have ever tried scanning priorty A and seen it work or not.
Also, all the new alert tones I have in 2tone section Standard, Continuous, Tone 1, Tone 2, etc... Those are all the same Minitor tones as seen in the Minitor programming correct? (So I don't have to guess which is which)
