Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > ICOM Land Mobile Radio
ICOM Land Mobile Radio - Discussion forum for ICOM land mobile radio equipment such as the IC-F series radios. Please do not post amateur radio topics here.
Old 05-26-2018, 6:01 PM
Default IC-121S Programming & Jumper F
All,
I picked up four IC-121S at Dayton this year really cheap. Want to use 2 in a backup repeater setup with an old CAT1000 controller. Would like to use 3rd for a Kantronics 3+ digipeater and one for a spare. None of these came with OPC-617 cables, so I basically made my own with a few parts from digikey.
A few questions as I've done some research and can't find the answers.
1) There are a few sites saying I need to solder Jumper F together. What does jumper F do when soldered?
2) I have the programming software, it reads the radio, but is there any instructions on the programming software? I could not find any on the web. Lots of options in the programming software, just want to make sure I have everything.
3) Has anybody else used one of these IC-121 or 121S with a Kantronics digi? Program the 3+, hook the db9's per the pin outs and it's good to go?
Old 05-28-2018, 10:50 AM
DODGEIT's Avatar
I can answer #3. I am currently using a 121S as a digipeater radio with a KPC-3. I got a cable from Associated Radio. It is a Kantronics 1200b to 6PMD. also this number CAB K101 It uses the microphone jack and also a wire that goes to the speaker jack on the back. Works great.
Old 05-28-2018, 6:24 PM
How did you plug that CAB K101 cable into a IC-121S? It's a DB9 to 6pin DIN??? There is no DIN on the back of a 121S.
Tags
ic-121s
