Hamradiostuffing
- Joined
- Apr 7, 2005
- Messages
- 317
This is a snip from mods dk
If you try to talk through an analog repeater, in digital mode, it will not work. The repeater must be able to receive a digital carrier and re-broadcast a digital carrier.
Since a digital carrier is different than an analog carrier, a non-digital radio can not re-broadcast the digital carrier. It's not just digital data, it's an actual digital signal. If you try to transmit, in digital mode, into an analog repeater, all the analog radios on the repeater will simply hear white noise and a digital radio listening will hear nothing. The digital radio will see activity on the signal strength meter, as would be normal when there is analog activity on the frequency.
_____________________________
Kevin McClinton, W7JRL
Amateur Technical Trainer
ICOM America, Inc.
2380 116th Ave. NE
Bellevue, WA 98004
Ph. (425) 454-7619
Fax (425) 637-8417
www.icomamerica.com
ICOM America, Inc.
2380 116th Ave. NE
Bellevue, WA 98004
Ph. (425) 454-7619
Fax (425) 637-8417
www.icomamerica.com
