Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > ICOM Receivers
ICOM Receivers - A forum for the discussion of all ICOM scanning radios and receivers. Please use another appropriate forum for transceivers.
  #21 (permalink)
Old 05-03-2018, 7:30 PM
RFI-EMI-GUY's Avatar
Originally Posted by ColoradoRedlands View Post
I too have a mostly dead R-7000. I do not have the expertise to work on the innards myself. Are there any shops that work on these things?
Will it operate from +13.8 VDC on the rear plug?
There are some excellent independent technicians. You might look at this list of reviews and see if one is near you.
https://www.eham.net/reviews/products/26
"Have Spectrum Analyzer, - Will travel" "Going Green"
  #22 (permalink)
Old 05-04-2018, 8:39 AM
Thumbs up
I dont have a power supply on hand to check that out.
Thanks for the list.
  #23 (permalink)
Old 05-04-2018, 12:03 PM
How long have you had this radio? Did it ever work? Is it totally dead?
There should be a white 3 or 4 prong plug on the back with a red wire that shunts the internal AC power supply to the radio. If that is missing, the receiver won't power up. There is an optional cable with black and red wires that can hook to an external battery, even a car battery to run the radio.
The internal transformer can fail. If it does I can recommend a replacement if the ICOM repair person tells you the transformer is no longer available. The part is about $45.
These radios still command about $350 on the used market. You can probably get half that selling it broken on e-bay if it is otherwise clean and unmolested. It is a great radio and worth the investment to fix it.
I should add, check the AC primary fuse on the rear panel to see if blown.
