Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > ICOM Receivers
ICOM Receivers - A forum for the discussion of all ICOM scanning radios and receivers. Please use another appropriate forum for transceivers.
Old 06-04-2018, 4:55 PM
Default AD-55A specs?
does anyone have the plug size/type and polarity for the AD-55A power brick?
I know the spec says "3 amps" but that's probably on the high side.
thanks!
doug
Old 06-05-2018, 1:17 AM
dkf435's Avatar
6.3 x 3.0 mm connector.Radio Shack " Q"
https://forums.radioreference.com/ic...connector.html
David
AR3000,5000,8000,8200,8600,SDU5000,5500,ARD25R1,10 ,20,71,72,75,7000,7100,8500,PC/R100,1000,2500 PSR500,600,800,PRO668,2035,96,106,BC760,796,996T,9 96XT,396T,396XT,HP1,HP2,436HP,536HP,WH-TRX1
Old 06-05-2018, 4:19 AM
ty!
