oceans777
Listener
Atlanta Public Safety System is P25 Phase 2, I put the frequencies in two IC-R30 receivers with Remtronix 800 MHz antennas - very busy voice traffic, no system tracking obviously. In fact traffic on the IC-R30's is busier, more interesting than the SDS100's most days.
Same system frequencies in both IC-R8600 receivers updated to FW 1.33 (but ran at 1.32 also) and neither 8600 manages more than an occasional RX pop-up with no audio or just a second of garbled audio. Digital monitor set to Digital but tried Auto, used the same antennas and also a D3000 outside for the 8600's. Good LMR400, strong signals at the 8600's. D3000 antenna attached to the IC-R30 instantly grabs and decodes the same P25 transmissions.
Another local Type 1 non-encrypted (DeKalb County) system on both 8600's has marginally better performance but still lagging way behind the IC-R30, misses a lot of the audio, RX pop-up fastest, most consistent on filter 3 but filter 1 is the only one that manages audio on this system on either 8600.
Appreciate any enlightenment, I know the IC-R30 is newer but are they using a different method to handle digital or ??
