I've been trying to get ARC30 to see my R30 SD card drive but no luck.
I've followed any info or instructions I could find here or in ARC30 itself for the correct radio settings but nothing works.
ARC30 will not see the R30's SD card which does show up in Windows 7 (64 bit) as a drive with a drive letter.
ARC30 version 0.90 Build 6 (Beta) says to use SD Card Mode which I tried.
I also tried Serial Port Mode. When in SD Card Mode, Win7 does see the card in the R30 when I hook it to my computer. Win7 also sees the R30 as a serial port when the R30 is set to Serial Port Mode so the R30 drivers appear to be working fine.
When I first tried this, I'd already installed firmware 1.10 in my R30 and did an Export from the R30's menus for all three available items.
When that did not work with ARC30, I downgraded my R30 firmware back to Version 1.06 but ARC30 will still not see the SD card when connected to my computer. I then went into the R30 menus again and did more Exports of my radio for all three settings again but while running firmware 1.06. I fired up ARC30 again but it will still not see the R30 SD card.
I tried installing the card into a card reader but still it will not be seen by ARC30 for anything.
About all I can do is use ARC30's Import feature and import the CSV files made when I used the R30's Export feature. ARC30 will allow me to work with those files and I assume I could copy them back into the correct folders on the R30's SD card and Import them back in using the R30's Import menu function but I know it is not supposed to work this way.
I should be able to read and write to the R30's SD card directly from ARC30.
I'm either not seeing something that is staring me in the face or something is really broken!
Anyone have any ideas?
I think I've probably tried every possible option with the R30's Menu Options but no luck at all getting ARC30 to read (or see) the R30's SD card. It simply will not see the card at all when mounted as a drive but in the R30.
Again, Windows Explorer sees the R30's SD card just fine when I plug in the USB cable and the R30 is in SD Card Mode.
I'm stumped! Anyone have any ideas or suggestions?
Gommert?
I'd love to find something that will work with this brand new R30!
ARC30 does not work.
RT Systems R30 Programmer apparently also has serious issues that have not been fixed (I did not try it as I don't want to corrupt what I have now).
Icom's CS-R30 software is Out of Stock at all places so I can't even buy it if I wished.
About the only thing I did not try was to go back to R30 Firmware 1.05 or even 1.04. I'd think ARC30 should see the SD card when the R30 is set to SD Card Mode regardless of which Firmware is on the R30 as Windows Explorer sees the SD card in the R30.
Stumped.
Thanks!
Gommert?
Stumped.
Thanks!
