Radioland in the database
jbertrand
Southern, IN
There used to be a system in the database for RadioLand. I think it was under Floyd County Indiana. Does anyone know what happened to it? Or is it hiding somewhere and I am overlooking it?
INDY72
Indianapolis, IN
Is that system even in existence any more? Its been marked out of use for over 10 years now.
INDY72
Indianapolis, IN
Though I do find several FCC current licenses...
https://www.radioreference.com/apps/db/?fccCallsign=WPXB659 800 MHz analog (EDACS ?) New Albany
856.6875
857.6875
858.6875
859.6875
860.6875
https://www.radioreference.com/apps/db/?fccCallsign=WPAC390 800 MHz analog (EDACS ?) New Albany
856.5625
857.5625
858.5625
859.5625
860.5625
https://www.radioreference.com/apps/db/?fccCallsign=WQTF932 UHF NexEDGE
https://www.radioreference.com/apps/db/?fccCallsign=WNYE310 UHF NexEDGE
https://www.radioreference.com/apps/db/?fccCallsign=WPRF442 UHF LTR
https://www.radioreference.com/apps/db/?fccCallsign=KXG602 UHF Who Knows, as it is liced for NXDN, DMR, and LTR
https://www.radioreference.com/apps/db/?fccCallsign=KIW326 UHF same as above
We need some serious research here folks... On all of these. Current status (are they active?) Are the EDACS ones separate or linked? SysID, Site ID, LCNs.... SysID and RAN and Site ID on the NexEDGE... And what are LCN on the UHF LTR etc If the 2 bottom are DMR, are they Con, Cap, LCNs, Color Codes???....
jbertrand
Southern, IN
I don't think that is the one I was looking for.
I have these freq. in the scanner and could hear 2 street departments on Friday and can also hear Wave3 tv sometimes.
856.0125
857.0125
858.0125
859.0125
860.0125
INDY72
Indianapolis, IN
Could be the KY site.. . Is it an EDACS, or Motorola? Most definitely active... So once you have it nailed down, please submit it to the KY DB! And if it is still active,.. Then good bet the rest are too... Need them looked at please folks
INDY72
Indianapolis, IN
856.0125
857.0125
858.0125
859.0125
860.0125
Any of them the CC? Or all VC?
If all VC, then the 854.0625 will be the CC.
jbertrand
Southern, IN
I have it as a LTR system in the Win500 Program. It had to be in either the IN or KY DB at one time since I have all the talkgroups that used to be associated to it.
INDY72
Indianapolis, IN
You getting above my knowledge there. I know CC is control channel, but what is VC? And how do I tell? I have Win500 software for my Pro 106.
VC is Voice Channel. If you hear an motor like sound it is an CC. If it is passing voice progged as LTR, then it could be an LTR system... But then the TG ID would also show up.... Any TG showing? And as far as I know, the listings were for an EDACS, not LTR.
INDY72
Indianapolis, IN
Program each in as an conventional freq. Listen manually. If you hear the CC sounds, then its EDACS, or Motorola...
INDY72
Indianapolis, IN
Also give an listen for the other 2 800 MHz sites and see if they are live.
jbertrand
Southern, IN
I set up all of these frequencies in my scanner as old conventional channels. Here is what I am getting so far.
https://www.radioreference.com/apps/...llsign=WPXB659 800 MHz analog (EDACS ?) New Albany
856.6875 motor noise
857.6875
858.6875
859.6875 scanner stopped on this channel but I do not hear anything. I have to tell the scanner to scan to get off this channel.
860.6875
https://www.radioreference.com/apps/...llsign=WPAC390 800 MHz analog (EDACS ?) New Albany
856.5625-motor moise
857.5625-motor noise
858.5625motor noise
859.5625
860.5625
ULS License - 800 MHz Trunked SMR (SMR, Site-specific) License - WPEP566 - RADIOLAND, INC. - Frequencies Summary
854.0625
856.0125 scanner stops on this channel but I do not hear anything
857.0125
858.0125
859.0125
860.0125
Where do you recommend I go from here?
INDY72
Indianapolis, IN
857.6875
858.6875
860.6875
858.5625motor noise
859.5625
860.5625
854.0625
857.0125
858.0125
859.0125
860.0125
Tune Mode for Analyzing Trunked System Frequencies:
Pressing FUNC TUNE while scanning or paused on a trunked radio system will load the control channel frequency into TUNE mode if the control channel frequency is the last frequency that the scanner checked while scanning.
Pressing FUNC TUNE while receiving a trunked radio TGRP will load the voice channel frequency into TUNE mode.
Or, you can manually enter a control or voice channel by pressing TUNE then enter the frequency and press SEL/ENT.
Use this to determine which kind of TRS it is. Once you know if it is an EDACS or Mot II, you can go from there!
Easier to Read Pro-651/652/106/197 - WS1040/1065 - PSR 500/600 Digital Scanner Manual
If the 106 is anything like the other GRE made Radio Shack scanners, it should display basic info on the CC.. Lite MOT, or P25, or ED...
And if MOT, it should also display the SysID, and Site Number. Same with P25. It looks like your getting at least 4 800 MHz TRS signals... Most likely, at least one is SAFE-T, one is the system your trying to nail down,.. And possibly the others close enough would be https://www.radioreference.com/apps/db/?sid=7282 or even the METROSAFE in Lville.
INDY72
Indianapolis, IN
For SAFE-T it would be P25 with
System ID WACN
6BD BEE00
For New Albany, P25 with
System ID WACN
45B BEE00
MetroSafe it would be P25 with
System ID WACN
1A6 BEE00
If not any of those, then we start building a system up.
