Aircargo said:
YOU SAID "all id's of the system will function."...what exactly do u mean....
Assume you are in Troop B area—If you scan ID SEARCH mode, every push to talk (PTT) will cause your scanner to stop scanning and display 4 lines of info during the transmissions.
Aircargo said:
under those 13 trunked frequences i put in... i can pick up all those id's (about 100) without programing it in....and...if theres traffic on a certain freq....
The PTT trips the CC, which assigns the freq for the communications and indicates to the CC, which Talkgroup is in use.
In ID SEARCH mode
Talkgroup ID is displayed on line 1 (MX-X:XXXXX)
Freq is displayed on line 2
Bank Scan List on line 3
System Alpha Tag on line 4
In ID SCAN mode
Talkgroup Alpha Tag on line 3
ScanList Alpha Tag on line 4 or System Tag if no ScanList Tag assigned.
Note: ID SEARCH mode, all Talkgroup ID in the system will cause the scanner to stop on their PTT signal to the CC.
ID SCAN mode, only Talkgroup ID’s programmed and unlocked will cause the scanner to stop with the PTT signal to the CC. An Alpha Tag programmed with any ID will be displayed on line 3 instead of the System Alpha Tag.
Aircargo said:
I WILL pick it up regardless,no?
You will pick them up, Yes…
Aircargo said:
...as long as those main 13 freq. are in...OR...do i have to put id's NUMBERS IN TO RECEIVE SIGNALs.? the alpha part i understand...its the system im trying to figure out...or the radio...how it works and to better understand....
You need programmed ID’s for scanning ID SCAN mode only (BTW, this is termed as CLOSED mode on the GRE Scanners).
Aircargo said:
Glad to help. If Walt Bertram reads these postings, he would be of great help for you. He collected a lot of the data for the NJ system posted in the RR database.
