KG4WHM said:Can D/PL Tones be used in a conventional system either that is using APCO-25?
Umm as far as I know there is no way to manually do digital coding, and from what I am reading, if your monitoring a digital system, you won't get interference. Anyone have any other info?
PJH said:IMBE radio's use NAC-Network Access Codes or Network ID
They range from 000-FFF in hex.
At this point, I don't think its too much to worry about picking up multiple IMBE radio's on the same channel
In terms of two-way radio's, there are several different ways that they can be setup.... unmute on propery ID only, selective ID (specific repeaters etc) and digital csq (you will hear any IMBE transmission on that channel).
PJH said:Project 25 is the APCO standard (Also called Astro25 by Motorola) for 9600bps digital trunking with CAI, and other aspects ...
rfmobile said:PJH said:Project 25 is the APCO standard (Also called Astro25 by Motorola) for 9600bps digital trunking with CAI, and other aspects ...
P25 isn't "the" APCO standard. There are numerous APCO standards - like Project 16, Project 39, and so on.
http://www.911dispatch.com/information/apco_projects.html
Getting back to your use of IMBE to mean P25. IMBE is also used in iDEN (Nextel) and Iridium Satellite phones. If you mean P25, please say so.
-rick
greg_miotke said:ITS SIMPLE SET YOUR PRO 96 TO 96 MODE AND PUT IN FREQ THE SCANNER WILL KICK OUT THE ID"S REAL SIMPLE............
IF U CAN"T DO THIS YOUR A MORERON!!!!!!!!!!!!
That sucks. What I hoping I could do was put a DPL/PL tone in with a frequency that had a digital signal and I would only hear the people who where using that DPL/PL tone on that frequency. That way I would not hear anyone else, unless they had the same DPL/PL tone.
Hopefully in the future they will come out with a scanner that all that we would have to do is set that channel as digital only.
Mike_Oxlong said:Guess he's just another "moreron".
