Mike_Alpha
I have an AR8600MKII and I'm thinking of getting the ARD25 Apco decoder.
I understand that the 8600 has to be set to WFM mode to enable the 10.7MHz IF output. As an experiment, I output the 8600's 10.7Mhz IF and put it into my AR8000 set to 10.7Mhz NFM.
All worked well. But I realised that if all frequencies are set to WFM on the 8600, how will it scan, considering the WFM bandwidth is about 75KHz wide?.
This means that unless the frequencies being scanned are 75Khz apart, the scanner will stop on any active frequency within the WFM bandwidth. With 12.5Khz spacing now common, it is going to pose a problem.
Seems like we'll only be able to use the ARD25 in manual VFO mode.
