precoislen
Being new with the LTR stuff, did some research, and got the old Pro-92 fired up but am having some reception problems. Like I am missing transmissions somewhere. Maybe fringe area operations on the users end that is coming thru on some of it?
I can one system very reliably, as I am only about an mile from their downtown tower, and that comes in real good.
I have reconfigured this scanner a couple times and even have it set up on just one system, on three banks, programmed in three different ways on each bank. ie... Bank 1- all Freqs in the LCN in order, channel 1,2,3,4,5 and so on. Bank 2, freq in the LCN lined up as was suggested by somebody, and on Bank 3, freq in the LCN lined up as you would do with an Uniden scanner.
I get the same type of reception on each bank. I have tried different flavors of monitoring, all 3 banks on at the same time, 2 banks, and 1 bank at an time, etc... I am beginning to think maybe the scanner can't just track as reliably as it should. I am open to suggestions or comments from anybody on this who uses an has used an Pro-92 in the past.
By the way, I am only trying to track an regular LTR system, as I am aware you can't do an Passport LTR system..
Special thanks to Mr_Hankey for initially helping me out. His advice and information has been accurate and dead-on, and helped me get off the ground and running. 8)
