updating business band license info with the FCC
70cutlass442
hello! I have 10 licenses that need to have the company name changed. The owner of the company is the same, and the contact info is the same. Has anyone done this on their own or will a coordinator need to be used? Also, is there anything that needs to be done to show the equipment has been switched to narrow band?
Thunderknight
Bletchley Park
Is it just a name change to the company without a sale or transfer? That is easier to do.
Yes, you need to reflect narrowband on your license before 1/1/13 if it's not there already. If it was already listed with the narrowband designator, you can remove the wideband once you switch all equipment over.
Both can be done in the FCC ULS. It's not terribly difficult, but if you never used the ULS before you need to be careful not to mess anything up. Do you have the ULS password for those licenses?
70cutlass442
Thanks for the reply! Yes I do have the FRN and Passwords associated with the licenses. The business was not sold, nor did it even transfer owners. The business had several names at one point in time and would like to change them all to a uniform name. Everything else has stayed the same.
