All:
Curious question about P25 digital. I know that Motorola TRBO, in conjunction with a repeater only, you can have 2 talkpaths per frequency (though this is not the case in direct/simplex mode).
INTRO:
We have Kenwood & Vertex Standard P25 digital mobiles & portables that we use. I noticed in the programming software, the default setting for Vertex “Talkgroup ID" is "0001" (meaning talkgroup 1) and default setting for Kenwood is “Talkgroup ID” is “None” (meaning talkgroup 0).
So we decided to play around, create “talkgroup 1” and “talkgroup 2” in both radios using the same frequency (on purpose). When we talk on either talkgroup, the radio also receives the audio from the opposite talkgroup (which I thought it would not do that). So what I was trying to test here was, using the same freq {example 151.625 simplex NAC 300} is ch1 (t/g 1) & ch2 (t/g 2) and because it was the same NAC, ch1 & ch2 both receive (though each has a different talkgroup number). I’m sure if I was trunked, my theory would work the way I was thinking.
I was just playing around trying to see if it was possible for 2 people to talk on say 151.625 simplex NAC 300, and have another set of staff use talkgroup 2 for another conversation (still on 151.625 simplex NAC 300) and the conversations remain separate because of 2 separate talkgroups.
Thanks in advance for your input
QUESTIONS:
1. So am I confused that I thought P25 digital could do more than 1 talkpath (i.e. talkgroup ID #) on the same frequency?
2. If above is true, then the talkgroup setting in both radios would primarily be for a trunked system, not for direct/simplex mode?
INTRO:
QUESTIONS:
