EF Johnson 5100 ?
SCPD
QRT
Virginia
Excuse me, if this is in the wrong section.
I can't decode this model very well, even with the chart. Can someone help me out with decoding this # 242-5173-810ya5
/v\™ P25!
jim202
New Orleans region
/v\™ P25!
Do you have any idea what frequency range the radio is on?
It might help if you record the 2 sets of numbers that show up on the display when you first turn the radio on. These will determine which version of the software you need to program the radio.
Do you have a programming cable?
These radios are no longer supported by E. F. Johnson.
The drop in chargers are available all over the place. Antennas can be obtained from a number of sources.
ScanWI
MN & WI DB Admin
Wisconsin
# 242-5173-810ya5
5
1=5100 Series
7=700-800 Mhz
3=Standard, DTMF keypad
8=800 Mhz Antenna
1=Ultra high capacity, NiMH Battery
0=Black Housing
y=optional software installed
a=optional software installed
5=optional software installed
The 5100 is still supported and sold by EF Johnson. You can get new parts and options fro your local dealer.
Good solid radios. We used a lot of them on our 800MHz SmartNet system up until early last year. I hung onto a few of the better looking units. They worked as well as the XTS2500's, were cheaper and I preferred the slightly larger size.
Good luck with it!
SCPD
QRT
Virginia
# 242-5173-810ya5
5
1=5100 Series
7=700-800 Mhz
8=800 Mhz Antenna
0=Black Housing
Ah I knew I was reading my chart wrong :banghead:
Thank You for answering my question straight forward.
