I'm not sure if the answer to this question is P25 protocol-wide, manufacturer-dependent, programming-dependent, or (most likely) some combination of the three.
Assuming a single-site or a single-cell P25 simulcast, when a dispatcher at a control station uses a multi-select function to simultaneously transmit on multiple talk groups, does the system use a single voice RF channel to complete this call? Or a voice RF channel for each talk group selected?
I was considering proposing the option of staffed stations within our EMS system each being assigned a talk group dedicated ONLY to the dispatcher broadcasting a call to that station, allowing a radio assigned to that talk group to be used as basically a selective call dispatch medium. The caveat is, if multiple stations are dispatched simultaneously, would this max out the voice channel capacity on the system or cell. Now that I've seen the P25 dispatch pager concept, this seems even more enticing of an option.
Please feel free to chime in with any pertinent brand of system you may have the answer for. Thanks!
