Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Industry Discussion
Industry Discussion - General discussion forum for commercial and professional radio technologies. This includes manufacturers not listed below.
Old 12-22-2016, 11:21 PM
wrowzee's Avatar
Default Zetron 4010R service manual
Im looking for the service manual for the Zetron 4010 console. I looked everywhere and cant seem to find it. I did however find the programming and operation manual if anyone is need of those. Hope everyone has a Merry Christmas and Happy New Year!
Many thanks!
Old 12-22-2016, 11:42 PM
The service manual was an item that was not on the price list for Zetron. It was rumored to be available, but was more for internal use.
The 4010 went through a few changes over the years. Older ones needed DOS to program, newer ones Windows XP.
As of 2016, zetron went to a flat rate repair on this console, which I heard was reasonable price wise. Keytops and keys can still be bought, but not the underlaying "poppets", which require "flat rate repair" for replacement.
I was able to fix a few of these in the past, but as of last year, sold the last one. So all manuals went with it.
Old 12-23-2016, 9:15 AM
wrowzee's Avatar
Thanks for the info. It shows the part number for the service manual as 025-9228, but everywhere I checked showed it as not available. Could be the reason why I couldnt find anywhere to download it . I figured they would discontinue parts for these consoles when everything went pc based. The main thing im looking for now is the cps for the unit and the install manual pn 025-9227, mainly for the punchdown block diagrams. Im also not sure if it uses a different version cps then the M4010 does, its almost identical except for it being a rack mounted 4010R. I really like these consoles alot better then the newer pc based Zetron Max And Acom stuff, I guess its the look and feel of it is why I like it so much more. There is just something about getting that click feedback when you push a button and having actual indicator lights. Dont get me wrong, the newer pc based console are nice and all, just partial to the old dispatch console look. We have also had really good luck with these consoles and they seem to have held up amazingly well. The only thing I have had to do is replace a line card in one of the consoles after we had a bad thunderstorm, other then that the only time I had one open is to blow the dust out.
Old 12-23-2016, 10:46 AM
Default Punchdown 4010's
Here is a screen shot I had for the 4010 punchdowns. We no longer have Zetron gear, so the manuals went with them. Local ham radio shop took them as electronic scrap.
This is from the 025-9227 manual you mentioned though. I do think the rack and desk version of 4010 used the same CPS. But it depended on when they were made whether it was DOS or Windows XP based.
So if your consoles are different age wise you may need both versions of CPS. I once lost my software and cable, Zetron sold me a kit for something like $160-165? Don't recall how much for sure, but it was less than $200 for the cable and a disk with software.
The MAX systems do seem like junk, we went Telex as a result instead. There were issues with the demo radio system not being able to send MDC1200, and patching problems. Then it was compatible with Motorola XTL5000 mobiles but only with the "O-5" control head. Well we still used "W" series control heads. They may have changed this now that APX radios are out. They are part of Kenwood, and we did not want Kenwood radios. Their sales manager attempted the hard sale, we decided to go Telex.
The phone system was a joke. Mini ITX computers for phone servers, and third party gateways for everything. We just use Cisco gear and run Call Manager. Works great.
Good luck on your 4010. Call Zetron and see if they still sell a programming kit.
Old 12-23-2016, 6:05 PM
buddrousa's Avatar
Been looking at a 4010 console model with 8 vox ports that I may hook up to 8 scanners for a toy to play with.
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP SDS100 BCD536HPx3 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 TK2180 MD380x4 NX5300 NX5200
Old 12-23-2016, 6:15 PM
wrowzee's Avatar
8 Vox ports? Your probably thinking of the channel cards. If your just hooking scanners up then it should be fairly easy. If its set up for two wire tone control then all you have to do is run audio from the scanner to the punchdown block, or if its set for four wire then just run audio from the scanner to the rx+ and rx- on the punchdown block. Should be pretty straight forward since your only using it as recieve only, with that you dont have to even mess with tone termination panels or wiring up the ptt and tx out for local control. Bout the only thing that may take some time is setting the scanner volume and line levels so the recieve audio isnt too low or so high its distorted.
Old 12-23-2016, 7:51 PM
We have many IntergratorRD PC based consoles out there with agencies who insisted on some button panels to be installed along with the touch screen for this exact reason you describe.
Old 12-23-2016, 8:51 PM
buddrousa's Avatar
It is a console that I set up in mid 90's for a 911 Dispatch Center and it was not setup for tone remote so it will be very simple as all my scanners have line out on them
Old 01-04-2017, 5:50 PM
wrowzee's Avatar
I get what your talking about now. Wow, I didnt realize these consoles went back that far. They didnt start showing up around where I live and work until about 2001-2002. The console we have is from 2001 and other then a few channel card replacements, the console works just as good as the day we had it installed.
Old 03-28-2018, 12:41 AM
Does anyone know the manufacturer of the Zetron 4010 channel control push buttons?
I have acquired a used console that is missing many of the actuators and membrane inserts. Hoping to identify the Make/Model of the switches to obtain parts direct.
Old 03-28-2018, 6:41 AM
buddrousa's Avatar
You might can get them from ZETRON direct if they still have any.
Old 03-28-2018, 4:16 PM
Thank you for the information. I have since learned that the used console that I purchased for Amateur Radio integration will require a $400 Firmware upgrade in addition to the programming software!
For anyone considering to purchase a used console, be aware that it may have a version of firmware that is no longer compatible with currently available programming software.
Therefore, your investment may be much greater than you realize!
