RCA??
LubeckTech
Parkersburg, WV
I just saw a New RCA BR850 IS portable which they say has a 4 watt output. Upon investigation it I found this website;
Our History | RCA Communications Systems which looks impressive.
Funny thing is the ONLY place which sells this equipment is Discount Two Way Radio
https://www.discounttwo-wayradio.com/
So is the original Radio Corporation of America (not Thomson Consumer Electronics) alive and selling industrial radio products or is Discount Two Way Radio private labeling Hytera radios and sponsoring a bogus website trying to convince people RCA is back in the two way radio business?
cmdrwill
So Cali
NOT the RCA that we knew. The two-way section died in the late 80's, after the last service station got sold off tho several different 'investors'.
Again someone using a famous name. Like other brand name thieves. Browning, Tram, ect.
LubeckTech
Parkersburg, WV
Not only is Discount Two Way Radio the only source for these radios they are the only ones with programming software. The radios are supposed to be wirelessly cloneable but to get the first one programmed you have to send it to Discount Two Way radio. No software or cables available.
Hiding in a coffee shop.
Junk radios.
Someone at work bought a few of the analog models and wanted me to program them to match the rest of their radios.
As usual, they didn't talk to me first, just show up, "fix this" and expect me to make it all work.
Took some digging, but came to the same conclusion LubeckTech did. The shop that sells them is the only one that can do the programming. They won't sell software. I had them return the radios and purchase a few new Icom's in their place.
Junky Chinese radios. By the time they bought the radios, went through all the stuff with me and then sending them back, it cost more than if they'd bought the Icom's first.
Save your money and prevent headaches.
lmrtek
All that WAS RCA was dead and buried in the late 80s when GE bought them out then sold the consumer division to Thompson who was clueless as to how to run a consumer electronics company
The two way division was sold and renamed several times but in the end couldn't survive
I can literally call a Chinese company like Baofeng and have them produce the same radios with "Motex" on the label
If you look at Bearcom, and TEKK, radios, you will see that they look strangely similar to RCA
jaspence
Michigan
RCA name
It is not uncommon to see RCA, Zenith, Polaroid, Magnavox, and other defunct brand names show up on a product. Someone usually owns the right to the name/trademark and sells the right to use it on a product. I have a tablet/laptop small computer with detachable keyboard made using the RCA brand. Other than a touch pad limited by the driver, it runs Windows 10 32 bit very well and has a bright screen with good color.
Project25_MASTR
Millennial Graying OBT Guy
Texas
Beacom radios (at least current models) are relabled Icom and Vertex Standard radios. The software is standard software and the radios are actually labeled with Bearcom model numbers by the OEM.
Sent from my SM-T713 using Tapatalk
SCPD
QRT
Virginia
Looks neat and fancy with the blue display but like mentioned junk. We had got a couple to demo and like said they must do the programming. No go for the department that wanted them since things change time to time and it isn't ideal to have to send in a portable or all to be programmed when it can be done by techs locally.
