Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Industry Discussion
Industry Discussion - General discussion forum for commercial and professional radio technologies. This includes manufacturers not listed below.
Old 07-08-2017, 10:32 PM
Default BK Radios KNG P500
My Fire company is using BK P500 digital P25 16 channel radios. They are uhf in the range of 450mz to 512 mhz There are also different talk groups. If programed correctly, will a Motorola XTS 3000 work with our BK radios on the P 25 system.? I don't want to buy one of the XTS 3000 radios if it won't work on our existing system ( Digital Trunking ) UHF
Thanks for any repays or Help
Old 07-09-2017, 7:50 AM
rescue161's Avatar
KE4FHH
If you are talking about this system: https://www.radioreference.com/apps/db/?sid=7641 then an XTS3000 should work. But, you run into the problem of getting the 3000 put onto the system. System Admins don't typically allow non-agency radios to be put on their systems, especially non-supported radios, like the XTS3000. Motorola ended support for these radios years ago and you can bet that if there is ever a problem that the Admin will point a finger at the XTS3000 and say that it is causing issues.
Hams Against Magnetic Mounts
Old 07-26-2017, 9:48 AM
XLC_Comm442's Avatar
A XTS3000 will not work on their system. Yes you can technically flash a 3000 for 9600 trunking, but CPS only allowed it to work on the 800 models.
Old 07-26-2017, 10:13 AM
rescue161's Avatar
KE4FHH
Good catch!
