CAP+ Roaming
D
DaveNF2G
Guest
Is it possible to implement roaming between Capacity Plus sites by making one repeater common to both and setting it up to recognize both sites' color codes?
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
Do the systems have overlapping coverage? If they do, then this will not work at all. The subscribers will not know which system they are talking on. Since audio will only be routed to the system who gives the radio the "go ahead" message. So user 1 will not know if their audio is being passed on system a or system b. This makes predicting which group of users who will be receiving your message very difficult. If the systems are not within range of each other, then it will work only when the cap plus system rest channel is sitting on that one frequency. Cap plus by default changes the rest channel every few minutes or few transmissions. You can alter this behavior, but not reliably to make what you want to happen work properly. The only conditions I see this working under areif all of the following are met:
A system are not within range of each other. Subscribers will never be able to hear both systems at the same
B all frequencies, slot numbers, and color codes are the same
C all talkgroup numbers have the same function at each site
What are You trying to Do? TT.
D
DaveNF2G
Guest
I'm trying to figure out what a local CAP+ system operator is doing.
I have two 3-pair CAP+ sites on UHF for which I can only find the first two pairs. There is another CAP+ channel active that displays as a "third pair" (channels 5 and 6) and occasionally is a Rest channel, but switches between the color codes for the other two sites. I thought maybe it was a common repeater for roaming.
Both sites and this mystery repeater identify as Site 1. Physical locations are known to be different but within range of each other. Talkgroups shown on all 3 "sites" are numbered similarly.
Project25_MASTR
Millennial Graying OBT Guy
Texas
The only way you’d have roaming involved in Capacity Plus is through Linked Capacity Plus.
What you could be seeing is frequency reuse though. Not all that uncommon as you can set one reused repeater to disable itself when it hears interference from the other. Assuming you have ~30 miles or so between sites you can limit interference fairly well.
D
DaveNF2G
Guest
That is a possibility. I think I will just set up the same frequency twice as One Frequency DMRs with each color code and record it.
Does Linked Capacity Plus put anything on the scanner or DSD+ screen to distinguish itself?
TampaTyron
Phoenix, AZ
LCP will identify itself with site numbers in DSD plus. Also keep in mind that often people will get very loose with FCC licensing. Often shops will move frequencies, change emissions, power, etc without updating their license. TT
D
DaveNF2G
Guest
It appears that this particular shop is running LCP, because every TRBO system they maintain broadcasts a site number and a neighbor list.
I'm aware of the site swapping issue. Seen it many times, in government and private radio systems.
TampaTyron
Phoenix, AZ
Glad you got it figured out. I really like LCP; as attempting to deploy a multisite trunking system in the old days was a huge undertaking. TT
