HELP: BK GPH Code Guard Issues
BeermanCA
I'm having an issue programming/reprogramming a BK GPH. I have code plug im loading into the radio. While I'm on Ch. 1 I push and hold the PTT and release then say Ch. 9 flashes on the screen as a CG channel. The issue is in the code plug there are no CG channels programmed and this happening across different groups with a variety of channels flashing as a CG Channel. Can anyone give me any insight to fixing this problem or if anyone has encountered this before?
Regards,
BeermanCA
rsmith7799
Arroyo Grande, CA
So with the E/G and DPH you MUST program a zone with the Standard 16 tones in order for the CG to work properly. It sounds like it's picking up a tone from somewhere in the radio.
I usually program the 16 in a zone that I don't use all the time or on the Los Padres NF, I just put it in the zone that have the Forest's repeaters in it.
