Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Industry Discussion
Industry Discussion - General discussion forum for commercial and professional radio technologies. This includes manufacturers not listed below.
Old 06-11-2018, 11:31 AM
Default Apollo pager programming
Hopefully I have this in the correct section... I have a number of Apollo 924 pagers that I am looking to reprogram, we use then in a healthcare setting for a nurse call system and had to replace our paging transmitter... I am looking for any info on how to make a cable to program these pagers. I have the software and have tried installing the driver software on a couple different USB-serial adaptors including a USB-TTL adaptor without success.
Every adaptor will take toe driver update but the software is still saying that the programming board is disconnected. Does anyone have any insight that could point me in the correct direction?
Thanks in advance.
Old 06-20-2018, 9:06 AM
Any ideas would be greatly appreciated!!!!!!
Old 07-06-2018, 5:54 PM
captaincab's Avatar
Location: monitoring delco pa with gre psr300 pro2053 and bearcat 560xlt
Paging and wireless service enter and Wolfe communcations use to be appollo dealers try calling them.
Old 07-06-2018, 6:02 PM
edit: disregard last
Have you checked this out?
http://www.apollopagers.com/wp-conte...ing-Manual.pdf
If you're using that programming setup I would bet the problem is in the usb serial adapter. Also, perhaps if you're running it on a new computer it may be too much for that older technology. Some older stuff just doesn't play well with new versions of windows and newer hardware, much less usb/serial adapters.
