Pro-96 Trunking Question
Robbyboy
Cat Herder
Richlands, NC
I have a question. I want to try to track the Camp Lejeune, NC 400Mhz Trunked System. The type according to the database here, the system is a Motorola ASTRO 3600 Baud. My Pro-96 will not open squelch and I cannot figure it out. If anyone can help me, I would appreciate it.
Robert
Steve2003
Colorado
Did you program the base/offset? Many systems in the 400mhz range have to have the base and ofset frequencies programmed otherwise the scanner will open squelch. You will need a programming cable and a copy of win96 to program the base and offset frequencies.
mlevin
Baltimore, MD
First off you don't need win 96 to program base/offset.
While in an ID bank hit FUNC 2, there you'll find the base/offset. When you program that, go back to the ID bank hit Func 3. Make sure it says multi table. If it doesn't say that that switch it 'till it does.
You can find the proper base/offset in the dadbase under the system. From you're other posts it seems that you have them right. Just make sure FUNC 3 is set to Multi Table, and it should work. Good luck.
Robbyboy
Cat Herder
Richlands, NC
There is base, offset and step. I have the base, the offset is just a three digit number and its kinda vague. Any advice?
Robert
mlevin
Baltimore, MD
Offset should be 380 like it says. I'm not very familiar with what it does exactly. All I know is that if you got it right, it works. Steps should be 12.5 KHz.
DonS
Franktown, CO
ITYM "Table", not "Multi Table".
"Multi Table" is only used if there are multiple base/offset/step settings for the system - and you can only program those with external software (e.g. Win96).
jamiewmorris
Kingstree, SC
uhf trunking
As a few have seen, I have been finding some info on a possible site for a federal prison system close to me. What my major problem is gonna be is the base frequency, and offset; how could I possibly get this without trunker?? Any help?
mikey60
Oakland County Michigan
I posted a procedure for doing this in the other thread, but basically it's all trial and error.
