LTR Passport Scanners
Skud
Middleville, MI-Barry County(Near G.R. & Ionia
I saw a post a while ago saying to Scanner could get LTR passport. Is this still true? I see in Michigan under Kent county System
Type: LTR Passport
System Voice: Analog
Since the Voice says Analog does that mean a Pro-97 or newer Uniden like the BC246T can pick this up?
INDY72
Indianapolis, IN
There is currently NO scanner made that can trunktrack LTR Passport. Currently you must have an tapped scanner, and have LTRTrunk and LTRDump software to do it on an PC. There are some research projects in the works at GRE to try to do an Passport LTR capable scanner. But right now the priority on R&D is on an 700 MHz Trunking scanner by Christmas 2007 for the Radio Shack name to compete with the Unidens. If we are lucky maybe they will surprise us and have the LTR Passport capabilty done for it too. Currently you must program all the repeaters on the system as conventional FM/FMN with NO delays and monitor this way. Its a PITA with the Data Bursts every 2 to 4 seconds... But its all we have for now.;)
WayneH
Forums Veteran
Super Moderator
Your master site
I really wouldn't believe that source in the future if I were you.
The protocol isn't that difficult to implement if someone wanted to. I've been unable to locate anything legal that says a manufacturer can't use the protocol without a license but Trident Microsystems seems to require it to be licensed before it can be used.
obijohn
What Trident wants you to do is buy their repeater controllers. That takes care of the software license. Anything else...good luck. You have to remember that Trident got their start by reverse engineering EFJ's LTR protocol and then selling improved repeater trunking controllers which, I might add IMHO were superior to EFJ's.
