jlm7424 said:
Is their a scanner that can scan the mpt 1327 radio systems?
thanks any answers appreciated
The short answer is NO - but it depends on how you define 'scanner' and 'scan'.
The scanners in your tagline will monitor the individual channels used on an MPT1327 system, but they aren't able to decode the Control Channel information.
There are no scanners currently available, that will monitor MPT1327 systems in the same manner that your scanners will monitor Motorola, EDACS, or LTR.
WinRadio has a module (software) that allows decoding of MPT1327 signals, but is it a 'scanner'?
There are also hardware/software arrangements known as FTrunk and PTrunk, but would you call them 'scanners'?
