yankees6161
I have heard nothing from troop F for the last 2 days, I’ve changed nothing on my scanner. Any one else with same issues?
I'm picking them up just fine on my scanner.I have heard nothing from troop F for the last 2 days, I’ve changed nothing on my scanner. Any one else with same issues?
Are you picking up other KSICS traffic?Thanks, I guess I’ll try to make some adjustments
Yes. Every thing else in Reno county comes in fine
There are times where it is silent like that, so I'm starting to think it's not an issue with your scanner since you said all other traffic is fine. If you get out and about around Hutch, you might take that TRX-1 with you and see if your reception improves. From where I am on the southwest side of the city, I hit the KDOT tower no problem but the Partridge tower is essentially dead in the water.I really haven’t resolved anything. Now it seems to be silent for 3-4 hours at a time. I’m using a radio shack 800mhz antenna I also swap to a rh77 diamond. Results are the same. I have the TRX-1. Any suggestions?
You might also check and make sure everything is up to date on it (firmware, etc.) It shouldn't affect the operation but with all the technological advances in these scanners in the last few years I wouldn't put it past Whistler.I’ll give that try
It could be that there are no units affiliated to the Hutchinson tower.Why do they go silent from time to time?
It is possible, there is a coverage gap near Nickerson where they can barely transmit. However I doubt this is a case of not being in range.Meaning that they are not in range of the Hutchinson tower??
I just got home from work and I have tomorrow off, I'll hook my scanner up to the laptop tomorrow and see if I can get a good read on what is going on with the Hutch tower.Thanks
I’m interested to hear about what you find. Troop F is loud and clear this morning
