Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Kenwood & EF Johnson Forum
Kenwood & EF Johnson Forum - For discussion of land mobile radio products manufactured by Kenwood or EF Johnson. For discussion of Kenwood Amateur Radio Equipment, please use the Amateur Radio Equipment forum.
Old 06-09-2009, 10:19 PM
wcu02mpa's Avatar
Talking TK-790 external speaker pinout
Does anybody know the pinout for the external speaker leads on a TK-790. I assume it is with the 9-pin plug and not the 25-pin plug.
Thanks,
I was trying to daydream, but my mind kept wandering.
Old 06-09-2009, 10:48 PM
fire_master_21's Avatar
Should be pins 2 and 6
Motorola APX7000 VHF/UHF FPP
Motorola XTL5000 VHF P25
Kenwood Tk-5710H P25
Old 06-09-2009, 11:38 PM
wcu02mpa's Avatar
Default Thanks
That did it. This radio has amazing audio; it is a step up from the 730 for sure. It has very crisp and clear speaker audio as well as signal reports. I plan on remote mounting this radio. Do I run the speaker leads from the 9-pin when remote mounted. I see there is a 12-pin connector, but am not sure what that is for.
Old 06-09-2009, 11:51 PM
pins 10 and 11
pins
3 6 9 12
2 5 8 11
1 4 7 10
should all be on the attached image from my first reply
Old 06-10-2009, 12:08 AM
wcu02mpa's Avatar
Default Part numbers???
I see it....DUH!!!! Firemaster.....would you happen to know the part number for the accessory plugs (from mouser or somewhere else)???? I would like both the 9 and the 12 pin plugs. I got some of the TK-730 plugs from mouser but am having trouble finding these.
Old 06-10-2009, 12:16 AM
I haven't had a need for anything from mouser in a while so I haven't checked them. However have you checked out Kenwood parts for all Kenwood electronics ?
Old 06-13-2009, 1:37 PM
If you remote-mount your 790 and plug the speaker into the control head you'll be limited to 5 watts audio output. If you run the speaker wire back to the radio drawer you'll get the full 13 watts.
I run my external speakers to the drawers in my x90 radios.
Old 06-13-2009, 5:51 PM
n7maq-1's Avatar
There is a 0 Ohm resistor that you can move to give you the full AO from pins 10/11 on the C/H. I don't know the R number off the top of my head, I'll look it up and update this post.
Jim
Old 06-19-2009, 7:11 PM
Correct. According to the service manual you move a jumper resistor from R628 to R627.
I've never done this so use at your own risk.
Old 01-21-2010, 11:03 AM
On the 25 pin D connector, if I bring the audio out of pin 17, do I need to ground it with anything? I don't want to brick my radio. I'm using a TK-790 for a feed here, but need some audio!
TIA,
Tim
Old 01-22-2010, 12:58 AM
ramal121's Avatar
Pin 17 AFO and pin 18 earth (ground) is a very good unbalanced audio level to feed to a sound card. Do it right and use shielded cable.
Old 03-31-2016, 8:56 PM
Default No Audio
I just installed my TK 790H today, and have the remote kit hooked up. I have the ignition sense cable coming off the radio unit not the head. I have the sheet that shows the pinouts, and when I try and use either one of them, I don't get any sound. I tested the speaker and that works fine. It's just for some reason I cant get any audio at all. Any tips or thoughts?
Old 03-31-2016, 9:09 PM
buddrousa's Avatar
Here is the manual look at page 18 and page 19
http://www.repeater-builder.com/kenw...rvice-2001.pdf
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP SDS100 BCD536HPx4 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 TK2180 MD380x4 NX5300 NX5200
Old 03-31-2016, 9:23 PM
So if I read that correctly, I just have to run my ignition sense, and my speaker from the head unit not the big part of the radio?
Old 04-05-2016, 4:42 PM
toastycookies's Avatar
Default external speaker installation / pinout
Old 07-08-2018, 12:52 PM
Question Shorted Pins?
Do pins on the 9 pin molex connector need to be shorted?
TK-790H
Full-featured Front Panel KCH-11 (remote mounted)
To use the speaker output from the KCH-11 in the dash (pins 10 & 11 on the 12 pin molex), do any pins need to be shorted on the base 9 pin molex?
Larry
KJ6QVI
Old 07-08-2018, 4:59 PM
ramal121's Avatar
Reference the diagram from post 15. It shows the jumper lead needed to route speaker audio to the control head. The jumper is between pins 3 & 6.
