vfo on kenwoodr5000 is sizead up ,<help>
kc2rgw
Stupid question....
Do you know about the tensioner ring? The silver ring against the chassis is a spring tensioner for the VFO. Hold the silver ring still with one hand and spin the VFO counter-clockwise to loosen it.
If it won't move at all, you may have some grit in there or the spring got cocked...you should be able to push in on the silver ring to shift the spring around, maybe it will free it.
