I already have a TK 790 w/ remote head in my possession.
I have been looking at the TK 890's for a dual band setup. All the TK 890's I have seen are designed for no lower then 450MHz. Will it work below 450 for 440 ham? When in dual band setup, do you have 160 or 320 channels? Does it scan both VHF and UHF frequencies at the same time? Do you use one antenna for each radio or one antenna hooked to one radio? If I purchased a TK 890 with no remote head(Head mounted on radio), will it still work in the dual band configuration?
TIA,
Tim K.
TIA,
Tim K.
