All you need to do for radio rebroadcast on a siren unit is bridge across the speaker leads. Name brand sirens work with BTL audio so there is no damage to the radio.
If you use external speakers, no prob splicing into the wire. If you use the internal speaker, there's a hitch. If you terminate the sirens rebroadcast wires to a phone plug and stick it into the external speaker jack, it will kill the internal speaker. On a TK_X80 it was easy, just pull the cover and apply a solder blob to bypass the switching action. The TK_X180 would require you to pull the whole board up for this. Easier to snake the wire inside and go straight across the internal speaker.
There is AFO (receive audio) on the rear 25 pin connector, but it may not have enough oomph, depending on the siren.
VIA TAPATALK
