Tk 2180 firmware
nick223
Ottawa Illinois
I have a tk 2180 and been trying to install the latest firmware right now it has 18. But for some reason it won't take the firmware is checked in the software. Holding down the s and turning it on and sending it at 115,200 as the radio says. Checksum says the latest version after I run it but it still says 18 and not 22. any ideas
ramal121
Lots and lots of watts
Calif Whine Country
I don't know where you are looking at your firmware version number but the latest is V1.22. Where are you getting the 18 and 22?
The checksum is a valid way to confirm the correct firmware was written. It is calculated after a firmware write. You can also just check by "S" button + power on (prog 115,200) then press the top side button.
nick223
Ottawa Illinois
18 and 22 are just the lazy way to type out v1.22.
The version in there now is v1.18. But after I do the firmware update check some changes to 354c don't qoute me on the exact number I'm not at a computer right now. But the version still stays v1.18 and not v1.22
