I have a TKR-820 at a temporary location for the time being on 440. When a real weak, but intelligible signal is present, it sounds off frequency on the repeater output. Listening on the repeaters local speaker(input frequency) you can not notice the off frequency sound. I do not have the most ideal setup, but the antenna is a Diamond X-300, LMR400 from antenna to outside panel, RG-8X from panel to duplexer. Duplexer jumpers are all RG-214 double shielded. Previously I had a GE Mastr II in this same setup without any issues. It will be a little bit yet before I can switch out the coax to heliax all the way to the duplexer. Any ideas on this issue? Repeater or coax problem/issue?
Tim
Tim
