kenwood tk 890 not powering on
radioman16
mount ayr
i just bought a kenwood tk 890 off eBay. it has the remote kit . krk 7db, i cannot get it to power on. the ignition sense cable is hooked to the radio unit. when i plug the power cable in i can hear a relay click.
Any help would be appreciated thanks.
ramal121
Lots and lots of watts
Calif Whine Country
Oops, this may affect the other post I just replied to. If you have the KRK-7DB, then the set up was for a dual band radio. By not having the second chassis hooked up may prevent you from booting the whole thing up. You hear a click, do any pixels show on the display?
radioman16
mount ayr
no nothing shows on the display. and from the looks of it you are right about it being part of a dual band. is there a way to make it a single unit? thanks
mrweather
If it was "Radio 2" of a dual-band setup, you'll have to undo the hardware mods before it can be used as a normal TK-890 again.
