TK-3180 Portable Help
jeffycc
Nashua NH
Trying to program a TK-3180 using KPG-92D.
Need to program the portable to transmit a beep when it hits a repeater.
Thanks!
Jeff
jeffycc
Nashua NH
I beilive something like a PTT transmit beep, letting the guy know that he is hitting the repeater. Hopefully that helps. Thats how it was explained to me. Thanks!
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
It sounds like what you actually want is the repeater to beep when the radio user unkeys (lets go of the push-to-talk switch). I don't believe there's any way in programming for the 2180/3180 to know if it hit the repeater or not.
jeffycc
Nashua NH
I know there is a PTT proceed tone. And a release tone. The PTT proceed tone is on every frequency, right?
Jay911
The proceed tone is generated in the radio and simply tells you when the radio has finished sending its PTT ID (if you have PTT ID enabled). This wouldn't take a repeater into consideration at all, you could be on a simplex channel or not in range of any other radio equipment at all. And the release tone is sent over the frequency by the radio so that other users know you have finished talking (and not that you've just lost connection to the repeater). Neither of these, unfortunately, will tell the end user whether or not he's reached the repeater himself.
ramal121
Lots and lots of watts
Calif Whine Country
What you want to do is available for LTR trunked systems only. If you are trying to access a conventional repeater no such beep exists.
