EMF,
I am also interested in using the KTI-3. I would like to send data from an ethernet connection over the air (NXR-810 as a base station) to a mobile radio for low speed control. I know I can use two NX-800H mobiles in transparent, but I would like to use the NXR-810 on one end via ethernet. I am not sure if this is possible, but if you have another idea, I am all ears.
73,
Tom
tom.n3bsz@gmail.com
Tom, Using the NXR-810, you would have to have the pc connected to the RS-232 on the back of the
repeater. The KTI-3 is just a dummy box that takes RS-484 data and converts it to tcp/ip, and then UDP
on two ports, talks with other "boxes" using VPN conncections (by the book stuff) or is on a wide area local lan, you can communicate with other campuses / locations.
Data passing is transparent period in NXDN. What goes in, comes out the other end of the path or paths.
hence why I stated, the NXR would have to have the PC connected to it via the db25 and not ethernet.
Could there be software development for this? maybe so, but I have not come across it other than
KAS-10 and "canned messaging".
I will say this as a HAM, I can take D-Rats and NXDN and accomplish the same thing as if it was that
ICOM package..... email, texting (keyboard to keyboard) even send photos like the CONFusion thingie.
Difference is, with NXDN, we can send live video (or chunks of it...) over the air.
enough babbling. You get the jist.
EFM
nxdninfo.com
