Will TK-3200 work with TK-3402?
backyard22
My buddies has TK-3402-P radios. There are some used TK-3200 selling locally and I wonder if they will work well together.
Thanks in advance!
eric
backyard22
Correction:
I have seen some TK-3307 selling at good prices, would they work with the TK-3402-P?
Thank you.
nasir32
TK-3402
Thanks in advance!
eric
TK-3402 is a UHF 450-470 MHz radio, so is TK-3302 and 3202. you can use any radio that has this frequency range that cover that frequency. it could be 400 t0 500MHz but less than 450MHz will not work.
I am using with my fleet 3402 3303 3202 and some chinies radios as well. You need to be able to program them to the same frequency thou.
nasir32
Yes they are compatible if both are UHF models for same frequency range. 450MHz-470MHz
