kenwoodgeek
So, to make a long story short, yesterday on the school bus ride home my bus driver gave me permission to speak to her from my radio today since she had a charter. The plan was for her to call me at 7:30 this morning.
I had my radio on all ready to go. Her transmission came through as clear as can be, as she asked me if I had my ears on. I pressed the transmit button, and the DTMF tones I just programmed into it sounded, and I replied. I waited a few seconds with no reply, so I tried again, no reply. At this point it was obvious she couldn't hear me for whatever reason. Knowing there were several other drivers out today, I did a standard radio check as well to see if anyone could hear me, and no reply at all.
So, I took my radio outside, plugged it all in, and put the antenna on the roof of our car hoping to get my signal out, still no luck. I came back in and reprogrammed the radio. I removed the DTMF tones and also tried adding the DPL tones I obtained from the database, but still nothing. Really disappointing. Here's a video of me trying to contact her, if it helps at all:
https://www.youtube.com/watch?v=Dg5vwcM-Z6A
So, here's what I know about the company's radios. They operate on 461.8875 MHz, and they are mostly Kenwood TK-8180s and NX-800s. I do not believe the system is trunked, but I can't 100% verify that. Does anyone know how I can fix this? Is it a compatibility issue between the 862 and the 8180s?
Thanks in advance!
Thanks in advance!
