I thought that taking the tones out would make the channel "line of site" or Kenwood's talk around feature, but now that I think about it the transmit frequency still remains, I must be confusing myself.
Talk around means that rather than transmitting on the input frequency, the radio makes the Tx and RX the same while in TA.
I was trying to go without using talk around feature because that's one more button that needs to be programmed
Minor, when just selecting a key assignment from a drop down menu.
and if you've had a 2180 or 7180 you know that your limited as it is with your key assignments, having really only 3 buttons that I can program.
Huh?
I own a TK-7180, and there are 10 programmable buttons... And with the use of the second function that makes 19 unique settings... If the TK-2180 has a full keypad, you have 19 keys, plus the second function makes like 37 unique functions.
Just remember that you need to set one key for FUNC so you can access the second function.
The TK-x180 series, and the NX-x00 are amazing radios. The key assignments are almost unlimited, except you do not get to select low or high power on the mobiles, you have to program a second channel as low power... Yet the portables can be set to have a key for High/Low power... PITA
Edit:
And if you put a speakermic on the portable, you get 2/4 more functions with the two keys on the speakermic.
