Kas-10 mapping
SAFFA
World
Hi Guys. With Microsoft stopping support for mappoint, are there any other alternative mapping solutions that are compatible with Kas-10?
I know you can use Google earth, but then you have no history replay and no geo-fence functionality.
I was reading that Bing mapping and maptitude are alternatives for mappoint, but will they work on Kas-10.
kd4efm
Florida
why not use the google earth option? You can also make your own maps to use in the program also.
EFM
SAFFA
World
I've been using google earth but as mentioned you don't have the geo-fence and history replay option on google earth.
Scanned maps options is fine for a small area or golf estate, but for a larger area its not a option.
amboman_bobby
hey guys how does one go about adding a map to KAS10 anyone got access to a manual or anything to walk me through it thanks
kd4efm
Florida
1 Google Earth is automatically done.
2 Look in your program menu, manuals there when installed.
kd4efm Evans, sent using TapTALK on my HTC M9
kd4efm
Florida
Yes. But it is also automatically updated when google parses it.
tkinard
Newberry, SC
I'm trying to use Google Earth with KAS-10. I've set everything up as per the instructions. I see each radio (truck) in the fleet, but their location never changes. I have Google Earth set up to refresh every ten seconds. It seems that KAS-10 is not up dating the KML file. Any help on this matter?
domes
Do you have mobiles/portables programmed to TX GPS data at set timing? We set ours at 3 minute intervals.
nnt236
Ha Noi
You can use nexetalk software if your radio is digital. It supports online mapping very well.
