I'm just trying to make the rear accessory connector a mic port. It's not in use and it keeps my dash clear of wires.
I have a general gist of what to do I just want to know if anyone else has done it that can give some guidance. The only issue is how to setup up the pins and kpg. Honestly if anyone could just explain what each pin does and if any of them relate to kpg I can figure it out myself.
The 25-pin D-sub connector is located on the rear panel of the transceiver and external devices, such as a Mobile Data
Terminal, can be connected to this connector.
Table 1-3 Signal Assignments for D-sub 25-pin Connector
Pin No. Signal Name Input/Output Signal Type Specifications Min. Typ. Max. Unit
1 NC - - - - - - -
2 RXD1 Input Digital Input Voltage Range -30 - 30 V Threshold Low 0.5 1.3 - V Threshold High - 1.75 2.6 V Baud Rate - - 19200 bps CL - 100 - pF
3 TXD1 Output Digital
Voltage Swing (3k Load) ±5 ±9 - V
CL - 100 - pF
4 AUXIO9 Input/ Output Digital
VIH 4.0 - 5.2 V
VIL -0.5 - 1.0 V
VOH (Io = -1.5 mA) 4.0 - 5.2 V
VOL (Io = 1.5 mA) - - 1.1 V
5 DI Input Analog
Input Voltage Range
(STD Deviation) - 0.5 - Vp-p
Frequency Response
(STD Deviation)
20 Hz - 9600 Hz
-3 - 3 dB
6 MI2 Input Analog
Audio Level (STD Deviation) - 5.0 - mVrms
Allowable Frequency 300 - 3000 Hz
Input Impedance - 600 -
7 GND - GND - - - - -
8 AUXIO8 Input/ Output Digital
VIH 4.0 - 5.2 V
VIL -0.5 - 1.0 V
9 TXD2 Output Digital
VOH (Io = -1.5 mA) 3.7 - 5.2 V
CL - 100 - pF
10 RXD2 Input Digital
VIH 2.8 - 5.2 V
VIL - - 0.65 V
CL - 100 - pF
11 GND - GND - - - - -
12 AUXIO7/
BER_DATA Input/ Output Digital
VIH 4.0 - 5.2 V
VIL -0.5 - 1.0 V
13 AUXIO6/
BER_CLK Input/ Output Digital
VIH 4.0 - 5.2 V
VIL -0.5 - 1.0 V
14 SB - Power Voltage This parameter depends on battery
voltage.
Supply Current - - 2.0 A
15 AUXO2 Output Digital
The type of this port is open collector.
VOL - - 0.4 V
IOL - - -500 mA
16 AUXO1 Output Digital
VOL - - 0.4 V
IOL - - -500 mA
17 AFO Output Analog
Output Level - 0.7 - Vp-p
Coupling Capacitor - 0.1 - F
Allowable Load 100 - - k
18 GND - GND - - - - -
19 DEO Output Analog
Output Level - 0.28 - Vp-p
Coupling Capacitor - 4.7 - F
Allowable Load 47 - - k
Frequency Response (STD Deviation)
Wide: 20 Hz - 4800 Hz -6 - 1 dB
Wide: 4800 Hz -7200Hz -24 - 1 dB
Narrow: 20 Hz - 4800 Hz -15 - 1 dB
20 AUXIO5 Input/ Output Digital
VIH 4.0 - 5.2 V
VIL -0.5 - 1.0 V
21 AUXIO4 Input/ Output Digital
VIH 4.0 - 5.2 V
VIL -0.5 - 1.0 V
22 AUXIO3 Input/ Output Digital
VIH 4.0 - 5.2 V
VIL -0.5 - 1.0 V
23 AUXIO2 Input/ Output Digital
VIH 4.0 - 5.2 V
VIL -0.5 - 1.0 V
24 AUXIO1 Input/ Output Digital
VIH 4.0 - 5.2 V
VIL -0.5 - 1.0 V
25 ME - Analog This is GND port for microphone
This is the best I can do for you.
Contact your dealer to order: NX-700_800_900_CSI_K_Ver280_EN_20120831.pdf
