Hello,
Does anyone know what TCP/UDP ports should be open between repeaters in a conv. IP network if there is a router with firewall between them ?
I'm trying to set it up, but I think there is a problem with network - when I transmit through one repeater, on the other one the diode is blinking green, and I see strong signal strength. But I can hear nothing...
The same pair of repeaters in a lab were working great. The lab was identical, meaning IP addressing, but there was no firewall, and NAT. And now it doesn't work, but there is a router between them with quite complicated config. But I can ping both of them, remotely connect via programming software and so on.
What other thing may be wrong if not unavailable some open ports ? (what ports ?)
Thanks in advance
Thanks in advance
