Jose_Rogers
Hello group, I have a 1 owner, 760 Kenwood radio that i have used for apx 20 years. Since I have owned it, I may have only programmed it 5 times. Its been a great radio with NO problems. Just recently I noticed the scan button when pressed will not work. If i press the scan button , it will make a loud BEEP. ok... now thats trying to get it to scan mode. I can leave it in manual mode (lack of terminology) and use the up and down buttons and and i can change the channels to any channel i want to, but i just can not make it "Scan". So i figured i would reprogram it. Programs perfect... on the first try. then I try to make it scan and it will not scan.... I have never changed any of the settings on the radio or program. I can only do manual mode only.
Would the microphone cable if it had a brake in one wire, would that stop the scan operation....? I can still key up and talk no problem....
I don't understand "Firmware" I know that is different from the regular programming software. But if I programmed a new firmware to the radio would that fix it or am I just wasting my time. Would like to thank everyone in advance for there thoughts and input. Please explain it to me on a childs level so maybe I will get it...... thank you all and have a great day....
